Yesterday I thought I'd be clever and clean my chain with engine cleaner. My chain came out looking as if it had been polished. It has never been cleaner.
Is this an acceptable method of cleaning a chain? Will engine cleaner cause any damage to my chain?
The bottle says it is safe for paintwork, plastics etc.
Johann will tell you that it will take out all the grease/oil/wax outta the rollers and you should npot use it !! I have been using it for years and it works for me ! But then again WAX based oils also works for me !
Same here!
As per pieman and DR (i.e. no this is not up for discussion cause it works for me!), paraffin to clean the chain in a bottle occasionally (buddy coke works quite nicely) and I use Squirt (wax based) on road and mountain (more often on the MTB).
Over and out
One thing though, I won't leave the chain overnight in the engine cleaner (eish, is that correct?).  As the grey beard wise one says, in the cleaner, scrub.  Then into an old water bottle, shake it up with a bit of Clean Green and boiling water (dankie oom H), then shake it up with boiling water and that's that.
Brakiesdown is a bit of a dodgy place lately !
Only since I moved in there, and only to the people living around me.  I've NEVER had any problems!!!
On a serious note though.  I have found that the chain rusts quicker if I leave it overnight.  DR, you remember my first 6 hour at Phambili???
ewep2008-03-25 07:17:27
Most bike shops (motorbikes) but it is not cheap !!
R100 a can.Helps if your friend is a racebike fundi.
You want a new friend?
The more the merrier.Thumbs%20Up
