Help me budget for my upgrade: 2015 Specialized Camber Comp Carbon
Muttley
Hi guys (including Spec haters  :ph34r: ),
So I've had me 2015 Specialized Camber Comp Carbon for a few weeks now and really loving it but even as a newbie, one can't help getting all caught up in the "need to upgrade hype".
Having said this, would you guys be able to help budget and plan the upgrades on my bike.
Specs are as follows (plus spez bottle cage, tubeless conversion and freebie shimano cleat pedals :thumbup: ):
FRAME
FACT 9m carbon front triangle, 29" geometry, FACT IS construction, M5 alloy rear triangle, tapered headtube, carbon PF30 BB, full internal cable routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 110mm travel
REAR SHOCK
Custom FOX Float CTD Evolution w/ AUTOSAG, air spring, lockout, rebound adjust, 197x48mm
FORK
FOX Float CTD Evolution 29, air spring, tapered steerer, Climb, Trail, Descend settings and rebound adjust, 15mm thru-axle, 110mm travel
HEADSET
1-1/8 and 1-1/2" threadless, Hella Flush style upper with 1-1/2" lower, cartridge bearings
STEM
Specialized XC, 3D forged alloy, 4-bolt, 6-degree rise
HANDLEBARS
Specialized XC, mini rise, 6000 butted alloy, 8-degree backsweep, 6-degree upsweep, 10mm rise, 31.8mm
GRIPS
Specialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, Others: XL
FRONT BRAKE
Shimano Deore BR-M506, hydraulic disc, dual piston, resin pads, S/M: 180mm rotor, Others: 200mm
REAR BRAKE
Shimano Deore BR-M506, hydraulic disc, dual piston, resin pads, S/M: 160mm rotor, Others: 180mm
BRAKE LEVERS
Shimano Deore BL-M506, hydraulic, alloy lever
FRONT DERAILLEUR
SRAM X7, 10-speed, S3 direct mount for DMD, bottom pull
REAR DERAILLEUR
Shimano XT Shadow Plus, 10-speed, SGS long cage
SHIFT LEVERS
Shimano SLX, 10-speed, trigger
CASSETTE
SRAM PG 1030, 10-speed, 11-36
CHAIN
SRAM PC 1031, 10-speed, w/ PowerLink, nickel finish
CRANKSET
Custom SRAM S-1250, 7050 alloy arms, 10-speed AM double, PF30 spindle, 36/22, 104/64mm BCD spider
BOTTOM BRACKET
SRAM, PF30, OS press-in bearings, sealed cartridge
PEDALS
Resin test ride, w/ toe clips, CEN std.
RIMS
Roval 29, alloy, 21mm inner width, 32h
FRONT HUB
Specialized Hi Lo disc, sealed cartridge bearings, 15mm thru-axle, 32h
REAR HUB
Specialized Hi Lo disc, 4 sealed cartridge bearings, 12mm thru-axle, 32h
SPOKES
DT Swiss Industry, stainless
FRONT TIRE
Specialized Ground Control, 60TPI, 2Bliss Ready, folding bead, 29x2.3"
REAR TIRE
Specialized Ground Control, 60TPI, 2Bliss Ready, folding bead, 29x2.1"
SADDLE
Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST
Specialized alloy, single bolt, 30.9mm
SEAT BINDER
Specialized 7050 alloy, single bolt, 34.9mm
Size M
Muchos Gracias  :clap:  :clap:
  • Replies 35
Upgrade those heavy wheels first. Expensive but will make the biggest difference to your ride. If you can't afford carbon look at something like the AC Wide Lightnings which are good value for money and would roll nicely on your camber.
I think Carbon wheels are rather pricey + I've never ridden a bike with them so not sure what effect they would have- I have however heard that they are amazing - I suppose for the price that you pay for them, they should be epic! I'll deff look into the Wide Lightnings as recommended- Thanks  :thumbup:
wheels, brakes, fork.
Wide Lightning, SRAM Guide, RS Revelation 130mm
Thanks for the input  :thumbup:
Wheelset - Crest/Fow - Hope Hubs
XT Brakes
Fork - Revelation 120/130mm
GX 1-11
BTW I have this bike as well
Again, thanks for this- I've read that if you upgrade the front fork, you need to upgrade the rear shock so that the travel in the same?
What about a command post/dropper post?
No. Rear travel stays the same. I don't know where you read that, but it's a pile of dog turd.
As for the dropper. Command post or giant dropper. Both perfect
X7 fd (equivalent of slx) slx shifter and XT RD. Sram 1250 crank (equivalent of slx / xt)
So ja, it is. No need to upgrade
Are you guys still speaking English- Eish ???? I'm completely lost on what you suggested above. I'm still a newbie at this..
Are you guys still speaking English- Eish I'm completely lost on what you suggested above. I'm still a newbie at this..
FRONT DERAILLEUR
REAR DERAILLEUR
SHIFT LEVERS
CRANKSET
Hi mtb new guy.
So you have a fairly decent stock standard new bike.
Rode the damned thing the way it is for now and get a good feel for the bike and how it handles first before you start throwing money away on needles upgrades.
If you really want to upgrade, get yourself booked into a good skills clinic and invest in your bike handling skills first and foremost.
By the time you have a decent skill level you will also know more about how you ride, or want to ride, and would have a better understanding of what would benefit you as a rider.
In my mind, the order of importance to get right.
Good frame in the right size and good geometry.
Best suspension you can afford
Beat wheelset you can afford.
Best brakes
Good tyre selection
After this all drive train components are expendable items, so ride what you have till it is kaput and then buy new upgraded parts.
My 2014 Camber's upgrades to date:
XT brakes
American Classic Wide Lightning wheelset (awesome!)
Eventually replaced groupset with 2x11 XT
Carbon handlebar and stem
