Rotor Inpower, Vector 2S
Thomo
Hi,
Any of you using these.?
Please share your thoughts/experiences.
Thx.
ROTOR for the win.
Using it on my MTB at the moment and it has only been a pleasure.
The new INPOWER Cranks are extremely accurate and all niggles an bugs that was present in some earlier POWER LT cranksets have been adressed.
We do stock them.
Vector - cannot comment as I have not used them.
I also use the Rotor Inpower on the MTB, and purchased through evo bikes.
Amazing piece of kit, absolutely love it. Very accurate.
Only issue is the battery door is a little finicky.
Battery lasts over 200 hours.
  • 2 years later...
I have a Rotor IN Power crank on my mtb but it just stopped working...
Anyone able to point me in a direction who can check this out for me? I was told the back up service for Rotor in SA is awful.
www.paragontech.co.za
I've had nothing but great service from them.
Speak to Richard
Hi,
Thx.
www.dcrainmaker.com
Vector2 has been plagued with problems. Hence Vector 3 which initially also had issues now resolved. I'd be looking for Vector 3S if the Garmin is the way you want to go.
then also consider Favero Assioma Single. Very good reviews and truly fit and forget.
The Vector 2 pedals are a nightmare to fit.
i now own the Vector 3 pedals and they are unbelievable! the data that comes from them is insane
Worth looking at the Favero Assioma pedals (assuming you're looking for a road power meter). I have the dual and they're excellent. No calibration issues, no fitting issues, they just work. Was a lot cheaper than Vectors and they look better and are lighter and rechargeable.
Paragon are the local distributors but are likely to tell you to work through your LBS.
Their offices are a stone throw from mine but I had to drop unit at bike shop.
Thanks Thomo
They do take calls to discuss a problem and assist you to troubleshoot before they need to see it. If the problem is not rectifiable then they will want the unit back via your LBS. Like I said, always had good service from Richard.
Where did you buy this from and what was the price if you don't mind me asking? Local prices seem unreasonable when one compares them to other brands like Stages for example.
