What will it go for?
mschulzsa
Hey guys
I have a set of Rockshox Tora 302 forks.
I'm not really sure what they are worth and since I want to upgrade to air forks, selling these would be a step forward.
Here are the specs (that I know)
Steerer tube: 1 1/8 inch
Wheelsize: 26"
Travel: 100mm
Axle: Currently using QR
Rebound adjustment
Preload Adjustment
I am hoping someone here could tell me what they are worth and whether I should consider keeping them or not.
Of the entry level coil shocks these were one one of the better ones. I had a RS-Judy 2 which was basically a slightly compressible rigid. I like how the Tora's have the  85 to130mm adjustment - but that was the 318 model.
Anyways, the 1st generation iPhone was also a hot item at one point.
I could recently get a second hand 26" Reba for R1000 and a brand new SR Suntour 26" coil fork for R700.Ended up buying a second hand Manitou Nixon for R800.
Would go with Brandon's estimate of R250 - R300.
Sent from my SM-G800F using Tapatalk
Geese, in that case I'll save up and rather keep it for another build, I knew it wouldn't bring much but was still expecting a bit more.
I have no idea what it weighs as well, but I've never been to stressed about weight, probably weighs like 1kg-1,5kg but I'm not sure.
Thanks for the feedback tho.
