Broken anthem rear swing arm
Gregc
If you are the original owner with proof of purchase, almost 100%
I'm guessing they'll just replace the rear triangle.
They may offer you an upgrade to a later year if they don't have stock with a small payin
T
Wow,
Not nice. Is this a freak happening or is it a common problem with an Anthem? I have not heard of it before, but then I live in the "country".
Sarge
Wow,
Sarge
Nope. No common on the anthem. Was common on the reign X cos they removed a section of it to allow for ISCG mountings. This was fixed in the 2nd production year back in 2011
Just replaced all the pivot bearings a month ago so definitely no bearing seizure.
Happened at the bottom of the trail before you head up to the top of Southern Cross drive. Just off the tar over the small roots
