Replacement for On One Pompetamine frame ?
kirstinS
Hi all
First post, please be gentle !
I've a much much loved daily commuter On One Pompetamine (m)
The frame is dead and I need to replace. Can't find one anywhere for over a year second hand
Can you suggest alternatives ? I'd like to keep everything else (i just replaced the alfine hub after 7 years abuse)
I'd like to keep the thin, steel frame looks and feel ideally.
However I have very little money so new roadrat frame, for example, is out of the question
Let's say 100 quid budget
Anything considered and all help massively appreciated
Many thanks
Kirstin
Noth sure if this On One is an option http://www.on-one.co.uk/i/q/FRPXKBD2/planet-x-kaffenback-2-frameset.
Else I see EvanB has a number of refurbed road frames in the classifieds, might be worth contacting him.
Thanks, I guess I'm discovering the issue is I've not got nearly enough know how. I'm just not clued up enough to if all my components will transfer !
I need to keep my own forks headset, bars, cranks, searpost - the lot !
When in doubt... Post pics of everything. So one of the whole bike, one of the head tube from the front, the bars, stem from the top, fork from front and side, brake callipers and mounts, crank from drive side and non drive side so you can see the bottom bracket, seatpost and seat clamp, see if there are any numbers on the seat post (like 27.2 or 30.9 etc.).
Then we can get a much better idea of what you have and what will need to be replaced if you get another frame. Generally a very helpful bunch.
Oh, and welcome to BikeHub :)
Ahh, that makes sense.
I might even have the spec sheet on the original e receipt at work.
Back tomorrow, cheers in the meantime
Kirstin welcome here. Where are you based? No info in your profile.
Sent from my SM-G900F using Tapatalk
I'll try to fix my profile but I am in the UK
I find the spec sheet, here
Is this enough info ?
OnOne Pompetamine Alfine Comp
Shimano Deore M575 Disc Brake Set Without Rotor / Front BIKE BUILD [CBOOPOMPCOMP]
Shimano SM-MAR160PS Post To IS Adaptor Rear / 160mm
Shimano XT SMRT79 Centrelock Rotor / 160 mm BIKE BUILD [CBOOPOMPCOMP]
BSSHXTROTOR-160
BTSMGPM-120-HON
01 Racing JIS Square Taper Bottom Bracket / 103 mm / BSA Thread / Aluminium Cups
FSA Gimondi Track Crankset -Silver 48t / 170mm / 3/32 In
basket pic
OnOne Pompetamine Frame / Medium
Shimano Alfine Rapidfire Lever / Black / 8 Speed / Right Hand BIKE BUILD [CBOOPOMPCOMP]
Shimano Xt Black 36h On Mavic 36h Open Sport Silver
RR Alfine 36h Sil Mavic Open
WRSHIALF36HSILMAVOPN
OnOne CNC QR Seatclamp / 298 mm BIKE BUILD [CBOOPOMPCOMP]
Shimano Deore M575 Disc Brake Set Without Rotor / Rear BIKE BUILD [CBOOPOMPCOMP]
Shimano Alfine Fitting Kit BIKE BUILD [CBOOPOMPCOMP]
Shimano Alfine Sprocket with Chain Guide / 18t
FSA OS150 Road Stem / 90 mm / White / 6 degrees / 318 mm Clamp BIKE BUILD [CBOOPOMPCOMP]
OnOne Mary Handlebar / White / 318mm Clamp BIKE BUILD [CBOOPOMPCOMP]
OnOne Smoothie Light Headset / 11/8 / Black / External BIKE BUILD [CBOOPOMPCOMP]
