Eagle GX upgrade
FCH
Looking at upping the gears fro 10 to 12; is it worth the expense and conversion?
Needed: XD freebody for the Hope 4 hub, Cassette, chain, shifter and a X-sync2 chainring that will fit a 4 bolt crank
All the bits and pieces will cost about R6500 in Germany.
Anyone running the GX group to report?
my wife will love your pragmatic view!
doing a middle of the road up to 11 speed?
Unless you want to, that is. But personally I'd put the cash into skills sessions and a holiday.
I agree with Myles, after moving from 10 speed to 11 speed, I really don't see too much difference. Just look at the aftermarket clusters.
A stag you may find is if you do have a short-cage derailleur. You may need to replace it.
quite a bit less hassle and cost going to 11 than 12.
what is your take on Box Two's 11 speed cassette; especially the jump between largest two being much closer than on the XT version 40-46 vs 37-46.
In all honesty I am not really fussed by the small gear ratio; I am however spinning out on the heavy side.
current set up is 32 front with 11-42 back; if I can do 11-46 with 34 front giving a slightly easier spin gear and some more grunt on flats.
will take a new shifter/ rear mach and casette....I think
Nope. Not necessary. If you do the upgrade to 11 you may as well do 12.
where are you buying your Eagles from??
At the prices that you can get a GX Upgrade kit, it is worth getting GX Eagle.
Box 2 is EXACTLY the same cassette as the sunrace. Literally. It's the sunrace with a Box lockring.
good to know.
sram gx vs shimano xt for rear mech??
I'm running BOX cassette with M8000 shifter and mech. 32T upfront when at the coast and 34T in Jozi. Very happy with the setup but IMO the shimano mech is at its limit in the 46 cog.
