SRM Battery Replacement
ColinMTB
Hi Guys, I need to replace the battery in the crank of my SRM power meter. Does any one know where I can buy a suitable replacement battery in Joburg? see my attached picture 1b60c0be9609595d486ccb274cd7dc94.jpg
I stand for correction but do you not have to calibrate the unit when you replace the battery?
You do
a quick google search will give simple instructions on how to do this.
Literally hang a known weight off the pedal, check the torque reading, put it into a spread sheet ( that you downloaded from your google search) then put the ofsett figure into the head unit. a 5 min procedure.
If zee Germans can do so can we !!!
I couldn't locate the correct battery locally but got a stash from The "small battery company" in the UK
