American Classic Hub
Balooba
I broke my American Classic wide lighting rim a while back. Got one on the hub at a decent price.
My current (broken rim) hub has a quick release on. The new rim has a trough axel.
Question - Can I convert it to quick release without costing too much? And if, how? :wacko:
Any help will be highly appreciated.
Cheers
Pretty simple exercise...lot of folks switched QR's for through axle so you could pick up The QR conversion  cheap here on the hub if  you advertised .With a little bit of a search you'll find a yutube vid on how to switch.
Thank you gents.
Would it not be possible to remove the current QR from my current hub and swop it with the new hub's trough axel? I only demolished the rim, hub is all good.
Thank you gents.
Yes you can swap it around
It's a fairly straight forward conversion...
As you said, It is the wide lightning hubs, they are convertible, however the older models are not, so you should have no issues here at all....
