Rear derailer craked screw need help to remove
Forthelove
Can any one suggest someone that can remove a cracked screw without messing up the carbon frame or derailer?
The screw was has seazed in the main arm support of the derailer.
Geniuses- yes it can come off the frame , as the screw that cracked is into the arm that supports the derailer to frame
Take the wheel off, take the hanger off, put it into a vice and drill the broken screw out... if you know how ofcourse.
Remove hanger, take the whole thing to someone with a drill press and an EZ-Out. Go past your LBS and order a new mounting bolt on the way.
