Fox float issue
JScottP
Went for a ride yesterday and the rear felt locked out no matter what position I put the shock in, so used a small Allan key to remove some air and repump when I got a squirt of this foamy liquid stuff? What would cause this?
It's oil never a good idea to try release pressure with anything other than a shock pump because the rear shock pressure is so hi pushing on the valve could let all the air out in a second and with that the little bit of oil and it could damage the seals. Pump it up again and see if it feels better but best to have a expert look at it.
could be float fluid that has served its life , requires a clean out of the aircan and shock and new float fluid
or it could be damper oil which is probably leaking from the bearing assembly , only way to fix this is A full rebuild which is costly
Service time...
There are a number of things that could be going on here, and a rebuild will sort most of them out.
