Does any body know where I could get hold of a Triple Tandem?
I tried Santana - but want to know if any available in South Africa.
db
Decibach2008-06-11 03:17:10
  • Replies 37
Guest Big H
You will have to stop and pick the bike up to make a u-turn..... where will you store this monster!!!!! You will have to build a hanger for the purpose and no boot carrier will be able to transport this. You may have to get a special "VEHICULO LONGO" sticker made for your trailer if you travel to Mozambique or Angola!!!!!!!!!
Try Francois Du toit cycles and he builds half bikes and  tandems so building a bike and a half should not be a problem. 021 021 910 0441 http://www.dutoitcycles.co.za/[/quote]
mdk555 I have been meaning to ask you' date=' if a single bike is a half bike, what is a unicycle, not a bike at all, a quarter bike?
Foe Fighter, you won't understand untill you ride a tandemWink
Guest Big H
*hijack*
Backslash how did your Kremetart go??????
*hijack*
Nie so goed nie Big H.  Ek was siek, het pennisillien gebruik tot die Woensdag voor Kremetart.  So ek het baie gesukkel, moes by einde van stage 2 ophou.  Die tandem is egter fantasties, ek dink nie ons kon 'n veel beter koop gemaak het nie
i know what you should do!
buy a normal tandem and 1 normal road bike, then you cut the normal one and stick it to the tandem with super glue!
hahahaLOLLOLLOLWink
This is the best there is.
http://www.calfeedesign.com/images/calfeetriple620x349.jpg
Calfee Design Tetra Convertible Tandem / Triplet
http://www.sandsmachine.com/p_clf_t2.jpg
Tandem configuration
http://www.sandsmachine.com/p_clf_t3.jpg
Add this section to the tandem and the result is the triplet shown below.
http://www.sandsmachine.com/p_clf_t1.jpg
Triplet configuration
Guest Big H
*hijack*
Nie so goed nie Big H.  Ek was siek' date=' het pennisillien gebruik tot die Woensdag voor Kremetart.  So ek het baie gesukkel, moes by einde van stage 2 ophou.  Die tandem is egter fantasties, ek dink nie ons kon 'n veel beter koop gemaak het nie[/quote']
Ken daai gevoel..... ek het 2006 se ARGUS gedoen twee weke na Malaria en 2005 se 94.7 'n week na ons in die Bakwena geval het. My elmboog was septies onder die roof. Ek het nie daarvan geweet nie en dit was so erg dat ek die Woensdag na die race 'n noodoperasie moes ondergaan met veloorplantings en al.
Maar jy is redelik jonk en jukkerig...... geniet die Tandem, ons doen ons s'n hier in Angolsh!!!!!!!
