WikusTri Posted October 3, 2018 Posted October 3, 2018 Need help building a xc/marathon bike. Couple perimeters:•X-Large•Carbon•29er•Dual Suspension •Sram •Black + White preferably Need options of frames, suspension or bikes (including where to buy these parts)? Budget +-40-45k?
Mic.E Posted April 18, 2019 Posted April 18, 2019 what happened to this thread? Let us know how this develops !
gummibear Posted April 18, 2019 Posted April 18, 2019 Bike&Brew in PE has some good specials going. http://bikeandbrew.co.za/?fbclid=IwAR0W1tkwcBUfLO5RutwPWD1uo3bK3XxTF3HfKvrWpGAXEy85AjjfYebFrBA
Eddie Stafford Posted April 18, 2019 Posted April 18, 2019 Need help building a xc/marathon bike. Couple perimeters:•X-Large•Carbon•29er•Dual Suspension•Sram•Black + White preferably Need options of frames, suspension or bikes (including where to buy these parts)?Budget +-40-45k? I have one of these, but you need someone that can bring it back from Europe. Bit old, non boost frame, but very nice ride. https://www.bike-discount.de/en/buy/cube-ams-100-super-hpc-sl-29-frame-teamline-629551
WikusTri Posted April 30, 2019 Author Posted April 30, 2019 I had found the bike for me. Check my instagram page out @wikusvn It shows you what i got
WikusTri Posted May 1, 2019 Author Posted May 1, 2019 BaGearA the post is on the minimum in that picture, but since then i put in a dropper that is also on the minimum insert. I am 1.91m tall and its a XL frame. But by Specialized’s minimum insert is 9-10cm mine at 9cm
PhilipV Posted May 1, 2019 Posted May 1, 2019 BaGearA the post is on the minimum in that picture, but since then i put in a dropper that is also on the minimum insert. I am 1.91m tall and its a XL frame. But by Specialized’s minimum insert is 9-10cm mine at 9cmA mate of mine is equally as tall, also on an XL and he got an even longer seatpost (Think it was a Gusset) from CRC for his bike. That is a lot of leverage you are putting on the frame.
BaGearA Posted May 1, 2019 Posted May 1, 2019 BaGearA the post is on the minimum in that picture, but since then i put in a dropper that is also on the minimum insert. I am 1.91m tall and its a XL frame. But by Specialized’s minimum insert is 9-10cm mine at 9cm I urge you to try and get A seat post or dropper that gives you more insertion, that seat tube is taking tons of strain at that length and weight (I assume if you're that tall you're probably close to 90kg)
MORNE Posted May 1, 2019 Posted May 1, 2019 +1 on the dropper. I'm 197cm and use my lyne xl 170mm dropper on the nr 2 insert line for roughly 860mm bb to saddle height...so plenty of post left inside the frame even with close to 300mm post showing. edit....the dropper also helps getting on the thing lol
gummibear Posted May 2, 2019 Posted May 2, 2019 Just needs some wider bars to balance it out [emoji848]
