LEZYNE Sport Floor Drive Floor Pump - HEAD REPLACEMENT
Veebee
Howzit All.
Anyone know where to find a replacement head for this pump in SA ? Have searched online and cant find anything.
I see Lezyne have a new type replacement head which would probably last longer, but have to get it from abroad itseems.
This is the pump, which was +/- R1k 2 years ago. The screw on head no longer works and holds onto the valve.
The new head.
https://www.sigmasports.com/item/Lezyne/Dual-Valve-Pump-Head/3HH8
I have the same pump, tbh I thought that head would be nicer as it is screw on but I keep on unscrewing the damned valve core. The clamp on type is much easier, Lezyne do those too. Otherwise awesome pump
Don't they come with a lifetime gaurantee ? When i bought mine it did, they fixed it twice already
Who did you send it back to for repairs ?
I got mine from Leighs cycles in Durban as they were the only ones with stock.
just email jono info@twowheelstrading.co.za
Howzit All.
The new head.
Hi VeeBee,
I've sent you a PM with my contact details.
We'll definitely be able to help you get this sorted out.
Kind Regards,
Jon
0413721418
jonathan@twowheelstrading.co.za
Are you talking about the Speed Chuck? (See Attached picture)
I ordered one from CycleLogic yesterday, they're not easy to get, and the warn O-Ring inside, which is the reason it's not holding onto the valve, is also not easy to get.
EvoBikes has it on their website, but it's out of stock.
Hi VeeBee,
Kind Regards,
Jon
0413721418
Now this is the kind of response we like to see on Bike Hub!  Well done Jono.
I think the issue here is the valves aren't tightened into the valve stem properly. there's a little tool for that, or a #11 spoke key will do it
TWT, who are the representatives in CT? Had mine repaired a while back, but the gauge has not been accurate since
Hi Alouette3,
Please send me your contact details and we'll help point you in the right direction.
Kind Regards,
Jon
0413721418
