Hope Pro 2 and Pro 2 EVO compatibility
Hairy
Yo Yo Yo
I have a Hope pro 2 Evo rear hub with XD freehub currently on my bike and needing to temporarily run the bike as a single speed .... now I have a older Hope Pro 2 wheelset in the garage (Unfortunately a 29'er rim, so can't use the wheel on my 650b frame) and am hoping that I could possibly carry over this free hub to my Pro 2 Evo hub as a temporary measure.
Are the two freehubs interchangeable at all please?
I am hoping you could please assist me.
I have a Hope pro 2 Evo rear hub with XD freehub currently on my bike and needing to temporarily run the bike as a single speed till I can replace my GX cassette and chain ring .... now I have a older Hope Pro 2 wheelset in the garage (Unfortunately a 29'er rim, so can't use the wheel on my 650b frame) and am hoping that I could possibly carry over this free hub to my Pro 2 Evo hub as a temporary measure.
I'll swop you the xd driver from my hope pro ii evo
I have an XD fitted at the moment that I would like to still keep .... just keen on running the shimano splined option to run SS.
You won't be able to change over the free bodies.  The Pro 2 has ID 15 mm bearings and the EVO has ID 17 mm ones.
are they the same OD? cause if the op is willing to go though the shlep he might be able to put another bearing in to make it work
Thanks Mr Marshall!
You can use the driver if you take the axle across as well.
Shotto .... so what are the chances of finding a 142mm hope pro 2 axel these days :(
Yeah then I could be hub hero for the day :D
if that is the hope 2 as per what hope are saying, and I understand the guys from Stoke, then that axel on the can be used with the hope 2 f/hub that I have as a spare and then fitted on the Hope pro 2 EVO wheels I want to run as SS .... so if that axel is collecting dust, please let me know how many boxes of smarties you would like for it please.
