Fox Stepcast 34, Hissing noise
Sidmouth
Just changed over to a Fox Stepcast 34 after 14000 km on my Pike non boost.
Love the Fox, light and great to have a full lockout again.
I do notice a hissing or breathing sound when riding very tough terrain and the fork is working hard, is this normal? its not an offensive noise, but is easily noticed
Only if its uncomfortable.
My Formula made that sound when I get near half way closed on the LSC, nothing wrong with it, but for my weight It happened to be a bit harsh, so I used less. Maybe you're a heavy guy and need more LSC to keep the fork from diving? Most folk use only a couple of clicks, unless you ride mostly smooth trails. go ride some long bumpy single track, repeat it a couple of times on different settings.
Could be rebound, are you A heavy rider?
Ie if your running a high pressure and therefor more rebound damping it could just be the rebound circuit making the sound
  • 3 weeks later...
