SRAM GX crank + Shimano 12 speed chain ring
Vishal72
Hi, I have a SRAM GX crank with an Eagle chain ring (non boost). I'm changing to a Shimano 12 speed drivetrain. Are there any chain rings on the market that are compatible with the Shimano 12 speed chain and fit the SRAM crank ?
Drop the guys at csixx a message, I think their chainrings are compatible.
You can use the SRAM chainring and chain on the Shimano Cassette and derailleur. Shimano claim you need to use their chainring and chain but the only issue I see is that it will be a little noisier than the Shimano chain and ring.
Just use your existing chainring, unless it's at the end of its life. No need to change.
You could also speak to https://www.rapide.co.za/
If I change cassette + Chain on a 1X System, I always change the Chain ring as Well.
Alu 1X Chain Rings 10 to 12 Speed are the Same and last about 5000 Km Average.
If the Chain Ring is worn it will give chain suck on a new chain but works fine on the old chain.
