Hi
I currently have a 32t chainring and want to swap out for a 34t chainring.
I am a bit confused about which chainring to buy as I see they come in 3mm or 6mm.
This is the crank that is currently on the bike:
SRAM NX, Boost, direct-mount X-Sync
The chainring just says: SRAM 32T Eagle technology x-sync 2 (no info about 0mm or 3mm or 6mm)
and it is a NX 1x12
Also, would I need a longer chain?
Thanks guys
will check chain length and get the 3mm.
This is just to accommodate the current amount of tar / pavement riding i'm doing. have seem to run out of gears.
If the chain is short, might leave it and use not use the 50T in the back as i will prob need to go back to 32t to climb up the hills on the gravel. but if i do get fitter then will add the extra 2 links. That was the reason for the question.
Thanks guys
Carefully check the back of your current chainring almost all of the newer direct mount chainrings have 3mm/6mm printed somewhere
Both Copperhead and Dirtypot are right. 3mm offset for a boost bike but be sure to check if your chain is long enough to accommodate the bigger chainring :thumbup:
Good idea in general to replace the chainring when you replace the chain. That is unless the chainring has very low mileage.
