19 minutes ago, Ruben Hechter said:
Here is the state of the inside of the clutch, also completely rusted on the inside
Ja, I'm afraid, rather get some replacements.  Maybe even used from damaged/broken one if you cant find stock.
40 minutes ago, 117 said:
Remove that cage and give the coil spring on the other side a good once over with cleaning material. I'll be at my LBS tomorrow and check if they have a new clutch kit for the XT - I'm sure they do. Will let you know
Doddy does a good tutorial on how to do it all yourself:
Thanks 🤙
O-ring on my wife 12-speed also worked just fine. Spring (outside the clutch assembly for those who have not delved there) is slightly rusted, but clutch assembly still looks brand new (she rides daily near the sea).
7 hours ago, TheoG said:
So far mine is 100%, no water ingress and no rust.  Running on 2 bikes (XTR & XT) for about a year now .... :)
4 off at home, no rust issues ... TOUCH WOOD !!  Certainly no issues at the last round of services.
rush off to check ....
On 9/13/2022 at 11:21 AM, Ruben Hechter said:
Thanks 🤙
Here you go Ruben - DM me and I'll send you the LBS details. They're in Germiston, Johannesburg
Replace these parts, give the spring a good clean and you'll be as good as new. And use the correct lube too - any decent light bicycle hub grease... not the junk for car wheel bearings
IMG_20220914_083607_resized_20220914_123606105.jpg.baa19c0d1d7201f11a9b0d8316b2ead6.jpgIMG_20220914_083616_resized_20220914_123605776.jpg.762614fa76b727bca5afdb6feb72f53e.jpg
Ruben have a look at the "short leg" and the "long leg" of the spring around the clutch.
SHORT LEG = screw side
LONG LEG = cam side
PS - I got the correct grease from Evobikes.  For home use it may last two, maybe three, generations ....
On 9/12/2022 at 8:16 PM, Ruben Hechter said:
This is how the P axle looks after I managed to pull the clutch off. You guys reckon a new clutch kit will do the trick or not?
20220912_200807.jpg.e184a17a442e913f9db2f066f33971ad.jpg20220912_200752.jpg.d469cf21430a7c58b7547c6ee01c04b6.jpg
On closer inspection, that doesnt look like rust but rather the previous owner (or you?) used the wrong grease on the clutch system. That brown gunk looks to be coagulated grease on the shaft itself. Im sure with some elbow work you can get it clean again and re-use that P axle and clutch. But dont scrape it off with a sharp blade or with sand paper. That will damage the surface the clutch rides on. Try remove the axle, then soak it in some strong cleaning agents like petrol, acetone, thinners etc to release that old grease
Of course, if you have 360 ronts then just buy new and be done with it
Definitely wasn't me as I know that no grease should be on that axle and to only use a lithium based high temperature grease on the outside of the clutch
I removed everything and turns out the clutch is faulty. I put a other clutch on the axle and worked fine. Thanks for the help!
Edited by Ruben Hechter
