19 hours ago, DieselnDust said:
That combo didnโ€™t work so well. The new Tiguan uses the same gearbox as the GTi which is designed for a much higher torque rating than the unit vw initially fitted ( designed for polo). Huge faux pas on their part but they learned quickly that cost cutting im isnโ€™t always clever even if the method of how you arrived at the numbers was. SA is not Europe and that little gearbox didnโ€™t cut it in that heavy body in SA.
Dude .... did you just call @PhilipVย fat!
  • Replies 48
