As anyone had any experience doing a tubeless conversion with non-ust Schwalbe Racing Ralph 2.1 Evo's?
I know Big Ben and some LBS have had success doing the conversion with non-ust tyres, however I've also heard of some where the side wall leaks.
They should work fine. The sidewalls of the gatorskins leak, but I havent seen another tyre doing it. They might leak a little but the sealant will sort it out quickly.
This sounds very, very promising. I think I'm off to my LBS for some tubeless valves and some Stans fluid.
BTW - I have Mavic X225 rims, they not marked as tubeless (UST) however they are sealed (ie - you can not see the spokes), I thought I'd wrap some fibre tape around them and use them as is with out a rim strip. Any comments or ideas?
You might have a problem sealing the lip of the rim. This is also where the rim strips helps. Give it a bash. Remember to use soapy water which helps the tyre slide and seal better.
This sounds very' date=' very promising. I think I'm off to my LBS for some tubeless valves and some Stans fluid.
FWIW - I would not do it without a rimstrip unless it's a real tubeless rim/tyre combination ....... but that's just me!
Mark, we have been doing tubeless conversions on Schwalbe tyres for just over four years now - no problems.
2 things should be  noted:
- it is much easier when done on rims that conform to ERTRO standards
- Schwalbe will not warranty a tyre that develops structural issues as a result of using "aggesssive" sealants. While many sealnt solutions work very well, they approve only their own sealant known as Doc Blue
Shamus' date=' is the Doc Blue sealant available locally? If so, where? [/quote']
it is available locally.
we supply most of the bike dealers, ask your LBS to order some if they dont have stock
I have a friend who did that conversion, but he warned me that if I tried it, it wont work i'm the wrong side of 80kg (tire burps)
JPW#,
like you , I am also over 80kg.
I have experienced this burping when running the tyre at too low a pressure.
The sidewalls indicate the minimum and maximum pressures to be used and should be strictly adhered to.
as a rule of thumb, I like to add 0.2 bar to the minimum pressure indicated for every 10kg over 70kg
I have a friend who did that conversion' date=' but he warned me that if I tried it, it wont work i'm the wrong side of 80kg (tire burps) [/quote']
Burping is an indicator of:
1) Too low tyre pressure.
2) Hitting something unusually sharp or edgy.
As you can see from the above conditions, weight plays a role. The heavier you are, the easier you'll burp at a given pressure. Pump your tyres or avoid edgy rocks.
