After using a compact crank set for a while now, I am looking at changing to normal/ bigger chain rings.
Uses 50/36 front, back 12-25, but this only gave me a advantage in climbs. With all the flattish / rolling hill races in WC I need something that gives more speed.
What is considered a good option 52/39 or 52/39 ? any thing else ?
53/39 I reckon is what 80% or more cyclists use these days (At least those without MTB type triples on their roadbikes ....), I guess that coupled with a 12-25 at the back?
Just get a 11-23 cassette, as a 50-11 gear ratio is actualy a bit bigger than a 53 - 12. You will still have the advantage on climbs and you won't run out of speed on the flats.
53/39 not very big ? Most new top end bikes come with these standard these days, so was just wondering.
Most races are undulating, and once in a while there is a climb (longer than 3km). I really like training on hills though, so what would be the best setup at the back ?
Do you change cassettes for races with hills etc or do you have another set of wheels for these ?
53/39' date=' and 12-21 at the back... I also have a 12-23 for hilly routes... [/quote'] But then again you weigh 25Kg!!!!!Smile
Wink
Just get a 11-23 cassette' date=' as a 50-11 gear ratio is actualy a bit bigger than a 53 - 12. You will still have the advantage on climbs and you won't run out of speed on the flats.[/quote']
I fully agree with this gearing - never been dropped even on a downhill with a 50-11
