Over the past few months I have bought a few boxes of various flavored WHASP gels only to find that most of the GELS have leaked inside the box , this causing waste to over the half of each BOX of GELS.
I have complained to the guys @ WHASP & they said that they had a problem with the machine which seals the gels & the problem was now sorted out.
They also said that they would send few complementary boxes of Gels for the inconvenience.
On Friday I bought some more Gels as I still have not yet received the complementary GELS & GUESS what, they all leaked over my race bag & I had no Gels for the race on Saturday.
The Gels are a great product if the doesn?t leak before you use them!
BUT I would suggest anyone looking @ trying them out rather not waste you money buy something else unless you want your stuff covered in GEL.
bd542009-06-29 06:44:59
The new system Whasp is using is the Gel is bought in a bottle, and then you decant whatever quantity you need into a small squeeze tube. It works really well, and has the upside that used sachet's are not littered all over the trail.
you now can take in whatever amount you need in a swig and can ride without having to fiddle the 'tear tag' into a pocket (or drop it to the ground)
I can aggree. Had a similar issue and he replaced my split sachets. I bought little plastic containers from a camping shop.Works much better than the sachets and no need or temptation to litter.
Then you limited to 1 type of Gel , I always use different flavors as they have different levels of caffeine. I will use they weaker gel @ the start of the race & towards the end I will use the Gels with higher levels of caffeine. I also prefer to split the gels into different pockets as when you mountain bike they jump all over the place if the in one pocket.
Anyone who chucks there litter should be shot that's including guys in Road races!!
no you are not limited to one type of gel.
I race with 3 types, blue crazy berry, kiwi green and the Protein yellow.
Three small squeeze tubes and I am set.
I have them each in their own pocket, so no fiddling between diferent sachet colours from one pocket.
works a treat.
no you are not limited to one type of gel.I race with 3 types' date=' blue crazy berry, kiwi green and the Protein yellow.Three small squeeze tubes and I am set.I have them each in their own pocket, so no fiddling between diferent sachet colours from one pocket. works a treat.
Most of my racing is on the mountain bike & I try limit the amount of stuff & weight in my pockets.3 Bottles of different gels is just to much extra stuff BUT 3 gels fits in really well.bd542009-06-29 07:17:11
Guest Big H
When in SA a few months ago I bought four sachets to try a product supplied by a Hubber. Before we got home two leaked onto our precription medicine (we normally buy for three months, so it was a mess) The other one started leaking before we went cycling so we decided to taste it. Berry or something...... absolutely repulsive taste!!!!!! I almost Luke'd from the taste!!!!!!!!
I was glad when I found my old trustworthy USN Vooma in Peach nogal.
I like the gels but find that the qty is just a little bit too much - would have prefered smaller amounts
MORE IS BETTER!ha habd542009-06-29 07:24:16
I have had the same problem with 2 boxes of the protein gels that have leaked out in the boxes and then the ones that I thought had not leaked in my pockets. I have been promised replacements by Jeff Norton since the beginning of May and have still not seen them.
I have had the same problem and even with the new boxes sent to me have leaked all over the place ... most frustrating. Why should we have to buy a bottle when we bought a product that should have worked in the 1st place.
