Hi,
Can somebody help me wit hthe following:
I have a Fox DHX 5.0 Coil shock...... Apparantly an internal spacer can be removed to increase the travel.....
1)  Has anybody done that?
2)  Who can service such a back shock - appart from Fox?
3)  Do any body have instructions on how to do it / drawing of the shock and its internals
4)  Does anybody know of somebody taht can do it?
Thanks and regards
Pappa Bear:
1.) Where did you hear of this internal "spacer"
2.) What is the year model and spec on your shock? [stroke and eye to eye]
3.) What bike is it on?
4.) Why would you want to do this?
Pappa Bear... just did an e-check for you, its not an internal travel chip. Its a travel chip under the bottom-out bumper. You can remove this yourself quite simply:
"NOTE: Stock setting for the shock stroke is 2.375?, resulting in 7.3? of travel. Travel can be increased to 7.7? by removing the small travel limiting chip located under the bottom-out bumper on the shock shaft.
When increasing travel, it?s recommended to reduce spring preload, or drop to the next lower spring rate to keep the recommended sag percentage."
Cool....thanks wil ltry it and let you know..........
As far as I know the DEMO range is not brought to RSA..... Only long travle bike is the Big Hit
Hi Johan' date='
Where are you based?  I would like to be present and learn if you do it.....
What does the old workshop sign say?
Rates:
R200ph.
With customer waiting: R250 ph.
With Customer looking over your shoulder: R300 ph.
With Customer actually participating: R400 ph.
With customer bringing the job in here in bits and pieces in a plastic bag, R600ph.
Choose one......
0823086847
Again, its not an internal change, its simply a travel chip which is slotted over the shock shaft in order to reduce its stroke. You should simply need to loosen the spring preload collar, push back the bottom-out elastomer and remove the chip.
Ah hA........ so that is what that disc is.....
saw it but could not figure out what the purpose was......  Guess Specialized spoke to Fox and asked for a shock that will give their bike 7" of travle so fox took standard shock with travle limit "disc"
I'll remove it and see if I can feel a differance.......
Thanks for your offer Johan, If I don't come right I will contact you.
