use any grease you like. get a syringe stuff some in and voila...there is nothing special about the cycle specific grease except the special price smiley2.gif
Paging Dr Bornman, Dr Johan Bornman.....
You do get different grades of grease, and whilst any or most will do the job I am sure there are also some other considerations and its not all marketing bollox.
I also got a nifty grease injector from CRC that takes that type of tube from the link above, that seems like a good thing to have in a portable tool box, but never seen it on the shelves here (hard to find anything on the shelves here)
kosmonooit2009-10-23 03:00:56
I've got a tube of Finishline grease connected to my grease gun. Got the gun (Weldtite) from Sportman's Warehouse, they have grease aswell. Grease and spanners I got from Westdene cycles.
Someone called?
I can help you with the tools. Grease comes free with its own magic applicator. johanatyellowsaddledotceeodotzeda
I'm not far from Cyclelab - a few Ks or two hours, depending on traffic between William Nichol and Beyers.
Any recommendations for GP sources of cycle-specific grease' date='  preferably in a tube like Exustar PTFE Grease, like here at CRC  http://www.chainreactioncycles.com/Models.aspx?ModelID=20645 Motorex from your LBS, I got the large tub at Linden Cycles for less than R400.00
And still trying to source a Shimano Cassette tool (BBB tool and chain whip also Linden or your LBS) and 17mm hub spanner.(Builders Wharehouse, tool shop, hardeware store) Went past Cyclelab in 4ways, did not come right there. (Very expensive place to shop, limited range)
Thanks in advance.  Pleasure
