Anyone has some experience installing a Polar Power Sensor?
I installed the power sensor as per the polar manual, but when I'm testing it, only the red light (Speed) comes on.
I tried to use an alternative magnet for the cadence sensor, but no luck.
The chain sensor is connected, but no yellow light.
I also replaced the battery
What am I missing?
I installed the power sensor as per the polar manual' date=' but when I'm testing it, only the red light (Speed) comes on.
What am I missing?
Heellooooooooo
Bring 6XBeer + Pizzas + said bicycle + said power sensor to MWNN posse = we will investigate towards great success.
OK - is this on your S720i or on the CS600? If the 720i - phone shammy rash, If CS600, refer instructions above on Beer and Pizza.
For cadence magnet I use a cateye round wheel magnet.  If you take off the plastic bit you are left with the round magnet with a 'screw'?? coming out of it.   I then chopped the 'screw' off it and glued it to the spindle of my pedal.
Works well for me.  ( I have the one for the 720, but should work just as well for the cs600)
