What do I need to become a home mechanic?
FanieFiets
I can get the following toolbox.
2/2.5/3/4/5/6mm Hex Wrenches
8mm Hex wrench
BB Cartridge Tool for Shimano/ISIS Drive
Crank Remover for SQ or Hollow Axle
Cassette Lock Ring Tool
Chain Whip
14/15mm Box Wrenches and 15mm Pedal Wrench
13/14/15/16mm Hub Cone Wrenches
8/10mm Open-ended Spanners
Chain Breaker (for 7/8/9spd)
8-groove Spoke Wrench
+/- Screwdrivers
6� Adjustable Wrench
4-in-1 Headset Wrench
Tire Levers
What else do I need?
Torque wrench? How much does it cost?
Do I need a bike stand?
Then I neem a manual. What is the best? Book or that DVD that they are selling in the bicycling?
Thnx all you clever people.
Link to comment
Share on other sites
  • Replies 37
8mm Hex wrench
Chain Whip
+/- Screwdrivers
Tire Levers
A good backup bike shop.
Link to comment
To be a home mechanic all you need is one shifting spanner, (or bicycle minitool) , much force, equla amount of patience and a very happy LBS in walking distance to repair the damage you do.
Alternatively,
At one stage there was a comprehensive bicycle repair manual online (I did down load it) (park tools has published the blue book as well)
or Mr Bornman of yellow saddles give a good bicycle repair course and wheel building course, so does cycle lab.
Working at a bike shop for about 6 months also equips you with a lot of the basic knowledge.
Remember lesons learnt slowly on other peoples bikes are invaluable, and cheaper than lessons learnt fast on your own.
Link to comment
FF i have the Bycycling DVD and although i have not looked at much on it what i have seen looks looks good. I have also got the Zinn Art of MTB maintenance which is also quite good.
Link to comment
2/2.5/3/4/5/6mm Hex Wrenches Check
8mm Hex wrench Check
BB Cartridge Tool for Shimano/ISIS Drive which ever one your bike uses
Cassette Lock Ring Tool Check
Chain Whip can make your own with a piece of blat bar and old chain
14/15mm Box Wrenches and 15mm Pedal Wrench Check but allen key oalso work on pedals
13/14/15/16mm Hub Cone Wrenches Check
Chain Breaker (for 7/8/9spd) Check
8-groove Spoke Wrench what ever you bike uses
+/- Screwdrivers Check
4-in-1 Headset Wrench don't know what this is. Intergrated headset onlt need a allen key
Tire Levers Check
Torque wrench? How much does it cost? Check, about R460 for the BBB one. Very nice tool
Do I need a bike stand? it makes live easier
Then I neem a manual. What is the best? Book or that DVD that they are selling in the bicycling? Park's Big blue book
If you do Johan Bornman's courses you get all the tools you need included.
Link to comment
Ja, hulle gaan meer geld uit my maak as ek die goed self probeer doen, maar dit lyk na fun!
Link to comment
Ja' date=' hulle gaan meer geld uit my maak as ek die goed self probeer doen, maar dit lyk na fun!
Oh....its fun alright....untill you have to put it all back together again...LOL
Link to comment
Start small, like chain removal and replace.  Then cluster removal, true a wheel, ext ext ext.
Leave the tough stuff (and irrepairable),  like shimming a BB bracket for the experts
Link to comment
Faan wat is die maak cvan die tools wat jy kan kry. Party van die tools is shocking. Mens het nie Park of Pedros nodig nie (die beste in my beskeie mening) maar BBB en Pro maak alsmal baie goeie tools. Die stel lyk baie nice. EK het vir my die BBB torque wrench gekoop ...... en dit die naweek gebruik. My Tandem se voorste BB is besig om te pak maar die "netwerk" hiernatoe werk so goed dat ek alreeds twee replacement op pad het wat vanaand inkom. Smart ne!!!!!Kontak Probike vir die Torque wrench. Ek glo dit is nie net 'n foeofie nie want ek weet dan verseker dat alles reg volgens spec vasgemaak is. Die *** gevoel in jou mond is nie lekker as jou handlebars afbreek omdat jy Tarzan gespeel het met die boute nie!!!!!! Ek plaas my "ontwerp" vir 'n stand om aan jou fiets te werknetnou in 'n tweede post.. Ek gebruik dit om met die tandem te werk en is cheap en maklik om te maak.
Link to comment
what is shimming a BB bracket?
Now, that sounds like fun? Should a get a grinder as well?
Where do I get that BLUE BOOK?
FanieFiets2007-10-31 01:53:53
Link to comment
Start small' date=' like chain removal and replace.  Then cluster removal, true a wheel, ext ext ext.
the one thing i want to learn is setting gears...looks difficult!!! very sensitive thing to do....too much turn then everythig  is out...and to get it back is K@K difficult!!!
Link to comment
nee man klink my jul kan als doen haal somer die STI lever ook uit mekaar uit...............Geek dis hoekom daar fiets winkels is !!!!
Link to comment
Setting gears is simple,  but as Clausewitz was apt to say "in war even the most simple thing is difficult".
however, setting gears with campy is a lot easier than a sludge filled Shimano MTB group set.  I am led to believe (by some MTB riders) that SRAM MTB groupos are as easy to dial in as campy road groupos.
Link to comment
Start by striping the spokes from your wheels the day before a race. You'll be amazed how quickly you master the art of wheel building.
Link to comment
Ek hoop dit maak sin Faan. PM my met jou email adres en ek stuur die skets vir jou. As jy die fiets stywer wil vashe gebruik van daai ratchet straps wat jy jou tent bo-op die sleepwas mee vasmaak. Mampara is die keer reg. Kry eers vir jou die Park Big Blue Book of Bicycle Repairs (enige REGTE fietswinkel behoort dit te he of kyk op AMazon of Kalahari daarvoor) en dan besluit jy of die tools in die kit die regte tool is. As jy darem 'n muurprop kan aansit behoort jy 'n fiets te kan regmaak.
Moenie luister na die suurtiete wat dit nie kan doen nie.
Ek gebruik die stand hierbo al vir =seker ses jaar. Nie een vna my fietse en dit sluit die twee tandems in was al ooit in 'n fietswinkel nie. EK hat aanvanklik wiele ingevat vir speke herstel maar na die tienduisendste gemors herstel het ek dit ook asook truing self begin doen. Enige dommie kan dit self doen. Dit is net die fietswinkel eienaars en werkers en die breinloses wat jou sal afraai om dit nie self te doen nie.
Big H2007-10-31 02:13:03
Link to comment
