How much should I be paying for this bike? I want numbers guys...
- Specialized S-Works Hardtail Frame Kit, M5 Aluminum, anodized silver, carbon seat post
- Fork DT Swiss XRC 100 RL, remote lockout, 100m travel
- SRAM X-0 groupset 2x9 speed, with 2011 crank 42/28, 175mm (3x9 also available)
- Brakes Avid Juicy 7 hydraulic, front disc 185mm, rear disc 160mm
- Selle Italia SLR Ti saddle
- DTSwiss X420 wheels
- Nokon shift cables
- less than 10.0 kg!
Here's the frame:
Thanks,
Skoffels
Edited by Skoffels
- Fork DT Swiss XRC 100 RL, remote lockout, 100m travel R9000
- SRAM X-0 groupset 2x9 - R12000
- Brakes Avid Juicy 7 hydraulic, R3000
- Selle Italia SLR Ti saddle R1000??
- DTSwiss X420 wheels R5000??
Approx R 30000-00
That's not including the frame??
Approx R 30000-00
Sounds like you know what you should be paying.... Personally I would put parts of that quality on a carbon frame
@Cannas: what do you think about the S-works frame? Is it not of the same standard at the other components? Think carbon would be a wiser choice? Would be significantly more expensive though...
New or used?
Not that I am familiar with Specialized products but that sure looks like an old-skool frame: it has V-brake mounts. And nothing really special about this components, check on CRC for new prices and compares. Cant believe that frame is worth more than a few Rk.
and SRAM 2x9? - you will need 3x9 if you are going to be doing any mountainous riding, unless you are Elite material. Or go with new 2x10.
Edited by kosmonooit
