Hi all
Can anyone please tell me where i can by those mountable skewers (and price +-) which i can mount to the back of my bakkie ( see pictures )
Thanks in advance
  • Replies 37
Got my HoldFast ones at Cajees Alberton (formerly Camaro Crossing). They're pretty pricey for what you are getting, about R300 each (including the V-thingy for the rear wheel).
If you have some rudimentary welding skills, I'm sure you could make some.
Otherwise, use a block of wood to attach to the rail. Drill a hole thru' the wood and insert a skewer, will cost you way less. The pic below is similar to the one I saw. The wood was a sheet, that was put against the tailgate.
Found these will searching for one made out of a board which I think is a brilliant and very cheap method. As soon as I find it I will post it.
Ni :thumbup: ce
