Chains: Is there really a difference?
Between HG73(LX/105) and HG93(XT/Ultegra) CN-7701(XTR/Dura Ace) is there really a difference???
Why is there such a cost difference?
Confused
Quality, weight, longevity all come to mind.
My 2c; don't waste your time on shimano chains, KMC/SRAM are as good/better and you can take them off to clean any time you like.
Dunno if they're compatible with Shimano as seems to be paulvs current groupset (assumed).
Anyway, I thought any Shimano or Campy component would spontaneously combust when combined LOL
No, I have campy gruppo on road bike and SRAM on mtb.
I am just wondering if replacing the chain with a SRAM 10 speed will be better than a campy 10 speed
c
there is still no real answer as to the difference between any chains... I have found that plating could be different and maybe the weight.
I tried to use a SRAM chain on a Shimano cassette (all brand new) and
the chain kept sticking when moving about 3 gears off perfect alignment.
I
then replaced the cassette with a SRAM one which is obviously different
from the shimano one in that it is missing one tooth on most of the
gears - I guess to facilitate a smoother gear change. Problem solved.
My
conclusion was that SRAM chains & Shimano cassettes don't mix.
Could have just been something that I was doing wrong though.
On vuh uvah hand darren I use the SRAM links on all my chains, shimano 9 & 10 spd included with no problems.
As for the diff between 105 & da chains - I doubt it very much.
Windbreaker2007-12-21 05:55:51
There is no real functional difference.
More expensive chains have nickel coating to keep them more rust free.
SRAM and Shimano chains and cassettes are cross compatible.
Although Shimano/Shimano or SRAM SRAM systems shift better, I have no had major ride stopping incidents with either product recently.
In the past (about 5 yrs ago) I certainly have had issues with the lower end products cross compatibility but with higher end parts i have seldom had issues that I can relate directly to compatibility. A 9speed system is afterall a 9speed system.
SRAM ESP shifters and rear Derailleur mechanism's are of course not compatible with Shimanos system by SRAM's design. This excludes chains
I once replaced my Record chain with DA at half the price. No noticeable differance but .... I am still so ashamed of myself - scarred for life!!!! CryLOL
All chain are the same and they are made in the same way. What I really need to know, what do you with your old chains??????? What is the correct and responsible way to recycle them?????
Just leave them at the lbs' date=' make it their problem.[/quote']
Sis on you, do you really let the LBS do this simple and mundane task for you!!!!!!!???????
Oom my lbs is 2 km from home, unlike yours ,980065 km from home.Big%20smile
When you buy tyres for your car do you take them home and fit them yourself?Wink
