  • Replies 358
Wh are those tools so expensive?
I think it's because the level of engineering required is a lot more than people think. You see a lot of companies coming out with ideas for sub-$1000 power meters and then, as they start to go deeper into the problem, the expected prices start rising and the delivery date keeps on getting pushed out. Look at what's happened to the Garmin/Metrigear pedals as an example.
Edited by Minion
I think it's because the level of engineering required is a lot more than people think. You see a lot of companies coming out with ideas for sub-$1000 power meters and then, as they start to go deeper into the problem, the expected prices start rising and the delivery date keeps on getting pushed out. Look at what's happened to the Garmin/Metrigear pedals as and example.
You are 100% correct.
The look system retails for around $2000-00 so Mr LOOK is pricing it according to LOOK's suggestion.
It's just a darn expensive toy. If it was priced around 12-14K I'd be interested but R22K without a head unit is an investment bankers toy.
I'll stick to RPE.
  • 7 months later...
Hmmm...
I could give up my visions of Quarg for this baby - Rotor's entry into the power meter market.
That crank looks shaxxy indeed.
http://www.dcrainmaker.com/images/2012/08/first-look-at-new-rotor-power-meter-thumb.jpg
Hmmm...
Yip! And available from us on Special Order...
Currently Ridding a set of Rotor 3D+ with a Power2max. Great value for money, Accurate, light and looks good.
Thinking about getting Power2max been hearing good things
