Thanks, do you use the black SRAm link or something else as I have read you cant get the black link off should you want to remove the chain? I currently have a KMC X10 chain with quick link that gives no problems.
You can get the black quick link off.
You can do it the difficult way using a pair of long nose pliers, or you can do it the easy
way by buying the quicklink pliers (about R80 at the LBS or CWC)
Edit: spelling
Edited by mrbaker
Been reading a bit and one one forum a rider uses the set up below to remove the link. A thin zip tie on the plates, a piece of brake/gear cable around the pins, use a pair of pliers and you should be able to pull it off?
I dont understand why SRAM has to make it complicated, as mentioned I have a KMC chain with their quick link and have no issues getting it on or off so wht does SRAM need to be different?!
http://forums.mtbr.com/general-discussion/stuck-10speed-sram-powerlink-603070-3.html
Edited by Mojoman
Just take a set of long nose pliers and pinch on the opposite corners of the link. Easy.
ie: on your pic you pinch on this side on the right corner, and on the back on the left corner.
Edited by wheelerdealer
