Question:
At the moment i have xp shifters that are bolted directly to the brake levers.
I want to change to XT brakes, will the shifters be able to bolt onto the xt Levers?
Edited by udxcob
X9 makes more sense, not sure about sram bolted to shimano though. I have xt bolted to xt but it looks different to the sram shifter clamps I had on my previous X9.
Phone your lbs maybe
Question:
It sounds like you have Matchmaker clamps, which enable the two to come together, using minimal bar space and a single clamp. You will be able to order standard X9 clamps and then the XT brakes will fht next to the shifters, albeit seperately.
Edited by CAAD4
This.
(Edit: Beaten by JanMTB, didn't see the link above the photo...)
Problemsolvers is a brilliant range.
Edited by droo
This.
Where are these products available?
Online for the moment. Looked at stocking them, but there's such a massive range...
  • 8 months later...
