1x10 conversion - Leonardi Racing/ General Lee Adapter
  • Replies 157
only if you already have a clutch rear derailleur, no need for that if you have a chain guide up front
This also has to be factored into your costs as you will need it with a wolf chainring
what exactky does a clutch/type 2 derailler do differently from a normal derailler?
Its suppose to keep the chain tensioned so that it isn't loose by pulling back on the chain.
The 104BCD Wolf.
Thanks Naas,
maybe you should run a special on the wolf chainring, Shimano/SRAM cassette, General Lee adapter and the clutch derailleur at some stage so that we can do the conversion.
I would need the chain and shifter as well as I am still on 9speed.
when its 'on' it only moves parallel to the cogs and not forwards it that make sense......
I did the Burger 60km this weekend on my newly converted 1x10 (Wolftooth 30 blade and 11-36 cluster on 29er). I am still running my XT Shadow RD without clutch and I had absolutely no problems. Chain didn't even hint at coming off and managed to not run out of gears going up or down. Made very sure to only have the 4 links overlap though.
I am so impressed with my purchase.
Edited by The Smoovf
