Bike Size - how much does it matter?
When I bought my MTB, my LBS measured me and suggested a Large, and eventually sold me a Large which I feel fits me perfectly.
Now, I want to buy a secondhand road bike. I'm 1.78 m tall, with an inner leg of about 89 cm. According to Calculator that means that I need a 59, but that I can consider a 57-61.
How important is it to stay within that range? I'll only use the road bike for the occasional 94, not for general training. Can I deviate, or will I end up cursing myself after 20km?
Hi,
I am 1.84, with the same inseam as you, and all calculators say I must have a 58. I currently ride a 55.5 with 10cm stem and 2cm back on my saddle, saddle height 75cm. It depends on your riding style / preference. I like to have my upper body low, but not stretch when I'm in the drops.
Long answer short, you can definitely deviate.
Edited by dee_biker
You will end up cursing yourself I am sorry to say. I've been riding on a frame that's 2cm too small for me for a while and just couldn't get relaxed at high speed. At low speeds it just felt very responsive, but generally OK - over 45km/h it sucked.
Agree with him, but you need to test it.
Edited by dee_biker
Bikes are expensive and the wrong size will make you hate it! I have had the wrong size Giant frame and after replacing it with the correct size Felt I only realised how important the correct size is. The wrong size will cause various problems such as neck pain, shoulder pain, ITB, etc, etc ... For the perfect fit I would also recommend taking your bike to Cycle Fit for a proper setup. 100% worth the 590 bucks!
THIS WILL END POORLY :blush:
Why? The reason I'm asking advice is to prevent catastrophe. What is looming on the horizon here? :eek:
s
sorry being negative, sorry hope you get your answers
Well, I asked if I can buy a bike of a different size than I should. TheHub said "no". I will listen.
I have the same inner leg measurement, ride a size 56 with a 130mm stem
Benefits: shorter tubes means stiffer frame, less weight and shorter wheel-base, resulting in a more responsive ride aswell as tighter turns!
How much you wanna spend?
I'm looking for a 2nd hand RC6000, there are a few of them on the classifieds for about R5k.
Seems like a visit to my LBS is simply a must. Ideally I know that I should see what suits me best, but I've never ridden a road bike for long distances, so I don't really know how "right" should feel. Also, I'm used to MTB, so the seating of a road bike will feel wrong, no matter how well it fits. So yeah, a simple question with a very interesting answer set! :)
There is no way you should be riding a 58cm bike. Unless your body has strange proportions. That's way too big!
I don't know what calculator you're using, but I think it's way off!
I'm 1.87 and I ride a 56cm - and that's confirmed through an Ergo fit session.
