Hi
I'm reasonably certain, but just want to confirm the following:
There is no plastic spacer between the hub and the largest cog/sprocket on a Campy Veloce 10 Speed cassette.
It didn't come with one and the cassette I replaced (also Campy) didn't have one, but i need reassurance.
I won't put my head on a block, but I had a Centaur 10 speed and I don't remember there being a spacer. If there was, I sold the groupset without it
It actually depends on the wheel and the spacing, you shouldn't need the spacer but if you have say 2 sets of wheels and the gearing is right on one but not the other then you'd be able to correct it with a spacer.
  • 1 month later...
