Go with tensioner...SS hub is rather limiting.
PS hub won't tension anything. Just removes the need for a spacer kit
in what way is a ss hub limiting? sorry ek weet nie hoe die goed werk nie, kan jy verduidelik asb? :)
Edited by CatGirl
Ek dink wat Rouxtjie na verwys is die feit dat jy die ss hub slegs vir ss kan gebruik en indien jy 'n gewone hub en tensioner gebruik jy die wiel net so oor kan gebruik indien jy nie SS wil run nie. Met 'n ss hub sal jy of 'n nuwe hub moet koop en die wiel laat rebuild of 'n hele nuwe wiel moet koop
I have some White Industries eccentric hubs.
They take up tension the same way an EBB works. I also have brake mounts that rotate on the same axis so its a no mess no fuss installation.
It is pricey but looks and works way better than a tensioner.
One is black and one in silver.....
ooo ok dankie :)
You can't decide to run gears on a SS hub like this one:
http://26bikes.interbikes.eu/file/3313/novatec-nt-256sbt-10-mm-rear-single-speed-hub.jpg
If you have a standard frame with vertical dropouts, you'll still need to run a tensioner. SS-specific frames have either horizontal dropouts like a BMX, an eccentric BB or sliding dropouts
Edited by divernick
pic?
I would presume she's refering to an eccentric hub...?
Edit: As per SSGuy...
Edited by Ryanpmb
This.
