  • Replies 43
Awesome fred
Out of interest...what steel tubing is the momsen made from?
I am a sucker for a good retro singlespeed.
From Reynolds' site
http://reynoldstechnology.biz/our_materials_525.php
COLD-WORKED CHROME-MOLY STEEL
With similar properties to our original 531 brand alloy. For cycling, these are mandrel butted for accurate profiles, and available in a wide range of shapes. Weight savings from butting provide competitively priced, light framesets. The Reynolds "520" range uses the same alloy, made under license for us in Taiwan and subject to the same quality standards.
Reynolds 525 range can be used for sports car chassis, suspension units, motorcycle race frames etc. in welded and fillet-brazed structures.
Why it works:
UTS: 700-900 MPa, density 7.78gm/cc
The same 0.30% carbon steel chemistry as our 725 range but without the heat-treatment process. The strength and ductility can be varied by cold-working and normalizing if required.
From Reynolds' site
http://reynoldstechn...terials_525.php
Why it works:
Schweeeet. Very cool.
Reynold or OX Platinum....really the best.
The Vespa colour you were originally after - it's called Baccarat.
A pic of my 2003 ET4
Very similar to Bianchi's classic CK colour.
  • 2 weeks later...
can you elaborate on what fork you've chosen?
this is starting to go slower than my build........where the pics at??
I've bought a Rapide Pitchfork. Very happy. It's with BogusOne at the moment for a lick of paint. Then...we cab FINALLY start building.
  • 3 weeks later...
Right. Sheesh. Seems the fewer the gears, the longer the build! Frame and fork has been delivered, working on the next installment and should have it all build up and ready to ride in a week(-ish).
BogusOne has done a killer job on the paint job. Couldn't be happier with his creative input as well as how nice it's come out.
