Hi guys i would like know if it is posible to rebuild a freewheel with any oarts bought localy or does it have to be brand specific?
Thanks!!
  • 2 weeks later...
Depends what's wrong with it. If it's wobbling because the yellow plastic bushing is worn (the most common failure) you're either going to have to get a new one or a hubdoctor kit. Both will require some lube to ease the extraction from your wallet
If it's just stuck, a cleanout will work, but then it's likely to have the play described above when you're done.
The bearing on the outer edge is a standard one available from BMG or similar, but the bushing usually goes first.
(mavic crossmax sl 2011)the reason for asking is that i heard they are getting discontniued and wnt to know how long i can keep them going gehetto syle(if that makes sense):)
The local agents keep spares of specific wheels for 5 years. But sometimes you may get lucky and find spares at bike shops (usually involves lots of phoning around)
I have a Sun Ringle Demon hub and the freehub has a mm or two play from side to side (cassette moves side to side). Will take it in to LBS tomorrow, might be locknut that's loose, but if it can't be fixed:
- where would one find a replacement, and
- can I ride with it like that in the meantime? Shifting is still solid and wheel runs well.
