Cassette adapter for Road bike
I know there are many options for a MTB cassettes to make the biggest cog a 40-42 T
Is there anything like that available for road bikes? I am looking for a 28T ?
Any ideas
  • Replies 33
Without buying a complete cassette I assume.?
Yes that is correct....I just want to adapt my current one :-)
It's possible to mix and match cassette bits, but I can't say that sales of various bits is very common.
So getting just the bigger cogs is the challenge.
Just note that there is a chance that you might have to replace your rear derailleur for a SRAM wifli or a Shimano XT to shift into a big rear sprocket
Only if you go 30 or above... :-)
I was hoping that some manufacturer has started doing the same for road as MTB where you can just add in a 28t or a 28/30t
I love my sram 11-25 just need a little more for the steeper hills with my MTB conditioned legs
also depends on your RD cage length, if medium or long you may be able to go with a bigger cassette than a 28, if you have a short cage RD then you will need to change it.
An alternative is to go compact crank at the front which will give you a smaller granny gear ir change the chainrings on your current crank
Already on a compact.....but riding MTB so much that I am not used to the Road gearing, want to rather spin up the hils in a 34/28 than 34/25
Just go a bit quicker with the 34/25 and you will still be able to spin
HAHAHA.......that is why I dont get right
