DT Swiss rear hub lockring removal
Justin_F
When you do it, have them make 10 or so, you can sell them in the classifieds section, that way you can cover the cost of the one you keep yourself.
Good idea...i will take one
At no cost , really ?
Have you ever removed one of these ?
Not to mention what they paid for the tool.
I don't mind paying for it, I know that bike shops are not charities and by servicing the hubs myself I'm effectively losing them out on some revenue. Also, from what I have read, you need to be the size of a gorilla to get these lockings loose.
I took it to a bike shop yesterday, who moved from a small vice to a big vice, and then broke their tool in the vice!! They said I should look at getting another hub because that lock ring is never coming out, but I'll try and take it to a Spez shop today to give it another shot.
You can have that tool laser profiled from 2mm stainless, just add standard 1/2 inch drive hole to the centre and use your Gedore rachet.   Less than 100 Randelas.
Good luck with that. If you have the arm strength of a silverback gorilla you'll only succeed in stripping the teeth off your "tool" or rounding out the 1/2" socket hole.
There's a reason the original is made from case-hardened tool steel and held in a bench vice so you can use the wheel as leverage.
The last drive ring I pulled out of an I9 hub took 3 people to crack loose like this.
Hehehehe...
They're not the first ones either...
If that's what it takes, then either it was over-torqued when assembled the last time or DT Swiss have cocked up the design.  You should not need such force to strip a hub.  I would scrap it and change to a better hub.  In the words of Sweet Brown....
I think its more technique than gorilla strength...
Took my wheel to a spez shop yesterday, who deal with these DT swiss hubs daily, and he had the lockring out in less than 20 seconds.
They had enduro bearings in stock, so they managed to get a sale of 6 wheel bearings and a set of headset bearings for their efforts.
Well then, as stated previously, clearly you went to a good shop
It's not assembly that torques it down, it's pedalling forces. If you want the drive ring to be easier to get out you'll have to weigh 30kg and ride like an old woman.
And even then, I know a few old women who would wind that thing in a good shot.
Just now we will have guys thinking bikes are waterproof and when water get to the BB it's a bad design.
Excpectations, Droo.
It's insane what the buying public wants .
Ja look, I'm all for user-serviceable stuff and I can't see any reason for the drive ring to lock that bearing in other than to stop the home mechanic from doing the bearings themselves, but maybe there's logic behind it.
I'm not going to second guess DT's design engineers. Unless it's on their shocks, that's an oke I'd like to meet in a dark alley.
  • 2 months later...
