Will this xt groupset work?
Runbikeswim
This is hela cheap, will it work in my scott spark?
Colour: Black
Option: 116 Link Chain/Long Cage Rear Derailleur
BoltCircle: 104mm
Teeth: 38.24t
Speed: 10 Speed
Length: 175mm
Material: Alloy
DerailleurType: Direct Mount
And if you do locally, you can even maybe ask them to do the shifters in the i-Spec version, allowing you to just have one clamp around the bars, nice and clean.
If you do the XT brakes do yourself a favour and get them with the Ice-Tech rotors.
I run a 180mm front and 160mm rear.
G
That groupo R4900 with duties is approx R5700 landed, add brakes at R2700 from easybike http://www.easybike.co.za/shimano-xt-disk-brakes-bl-m785-br-m785-set-black.html
You would be looking at R8400 in total
XT groupo with brakes R7000 at Solomons http://www.solomonsonline.co.za/CYCLING-EQUIPMENT/COMPONENTS/SHIMANO-COMPONENTS/MTB-COMPONENTS/COMPLETE-GROUPSETS/SHIMANO-XT-2x10-GROUPSET
So better deal at Solomons
