Building a Cyclo Cross bike
Meerkat82
  • Replies 2.2k
Hi all. I have a hardtail mountain bike, for the occasional offroad riding.
When I started cycling I wanted something that can do both.
I ended up 90% on tarmac and gravel roads, hardly ever true offroad.
So I started following this thread with building my own cx bicycle in mind, that would be lighter than my 16 kg hardtail.
Then I found the Silverback Scento. Its pretty good looking and was wondering, what do you guys think of this bike, and if it will work if I just replace the straight bars with road bars?
Here is the link to silverbacks page: http://www.silverbacklab.com/bike/city-hybrid/silverback-scento-1/
This being the most expensive one. The Scento 3 still have a steel fork without disc brakes.
Here are the details of the bike...
Any inputs are welcome, since my technical knowledge is limited.
  • FRAME: Silverback Custom, 700c Aluminum City Sport Frame, 6061 Butted, Tapered 1 ⅛” – 1.5“ Headtube, Key Join Smoothwelds, 135mm QR Dropouts, Fender & Rack Mounts and Replaceable Alloy Hanger
  • FORK: Silverback Carbon Fiber Aero, Tapered Alloy steerer, Postmount brake mount, integrated cable guide
  • RIMS: Alex Black Dragon, Alloy Double Wall, 32H, Stainless Steel Eyelets, Polyurethane Rimtape, Black, Custom Sector Decals
  • HUBS: Rear: Shimano FH-R505, Centrelock, Adjustable cup and cone angular contact bearings, cassette, Silver Front: Shimano HB-R505, Centrelock, Adjustable cup and cone angular contact bearings, Silver
  • TYRES: Vittoria Rubino Pro Slick, 700x25c, Kevlar Bead, 150TPI
  • SHIFTERS: Shimano Tiagra, 3 x10 Trigger, Silver/Grey
  • FRONT DERAILLEUR: Shimano Tiagra FD-4603, Triple, Clamp on 34.9mm, Silver/Grey
  • REAR DERAILLEUR: Shimano 105, RD-5701, Long Cage, 10spd, Silver
  • CRANKSET: Shimano FC-R563, 50/39/30T, 36/40/44cm L: 170mm; 48.5/52.5cm L: 172.5; 56cm L: 175mm, Silver
  • CASSETTE: Shimano CS-4600, 10-Speed, 12-28T, Silver
  • BRAKE SET: Shimano BR-T445, Resin Pad, Hydraulic caliper, 160mm Rotor F+R, Centre Lock. Brake Levers: Shimano BL-T445
  • SADDLE: Sector City Series, Cr-Mo rails, w/Comfort foam
  • HANDLEBAR: Sector Plane Alloy, W: 620mm; Back Sweep: 9° x ∮31.8mm; 6061 Butted Oversized
  • STEM: Sector Reach Alloy, 3D Forged Alloy, Ahead, 36/40/44/48.5cm L: 80mm; 52.5cm L: 90mm; 56cm L: 100mm; 7° Rise ∮31.8mm, Black Bolts, Black finish
  • SEATPOST: Sector Level Alloy, ∮31.6mm x 350mm; 1 Piece Alloy, Black
might be a good option, juts watch the TT length as it looks longer than normal road bikes, so a shorter stem will be needed for sure.
will need new brakes along with some STI's.
then some 32c tyres.......
Thanks for the input.
I understand everything you are saying except STI?
What is STI?
Heading to lbs to see if they have one of these babes in stock.
The racing division of Subaru .
