Part of shifter case fell off
brucem76
My LBS just ordered the missing cover. No need for complete set. (Probably depends if LBS wants to keep you as customer, or just try and make a quick buck)
For now until you get new one it is ok to ride without cover. I just taped mine closed with electric type untill cover arrived.
Same issue on my SLX shifter and after LBS shop supplied two covers which did not match, replaced with a new shifter.
Where are you? Why would you have the spares?
You're new here, no??   :ph34r:
Most guys (BB and a few others especially) have a healthy spares bin with all the odds and ends gathered over the years that they often tap into to help fellow hubbers out with  :clap:
Hi there
Who is your LBS cause mine can't help me.
