  Quote
  Quote
  Quote
Big Bill ?
Big Ben? That name rings a bell...
Give it a bit of time and you might recall where you heard of him...
Word on the street is that he has a towering intellect...
I do Big%20smile
  • Replies 170
  Quote
  Quote
Don't ever race against him: I hear he's a bit of a ringer...
LOLLOLLOLLOLLOLLOLLOL
  Quote
  Quote
I want try the tubeless conversion on my road bike too...Just 1 question:
When the tyres are worn have to be replaced' date=' how much of a mess is it when the tyre is removed and how difficult is it to clean the rim up for the new tyre?
Rather worry if you have a blow out on the rear tyre...... goo will be sprayed everywhere and it will be messy!!!!!!!!
Big H i had a rear tubby blow out on me before which had slime inCry....I know the mess it can makeDead
  Quote
  Quote
  Quote
  Quote
Big Bill ?
Give it a bit of time and you might recall where you heard of him... Word on the street is that he has a towering intellect...
I do Big%20smile
Typical for you to chime in like that...
  Quote
Lurker' date=' how long since your conversion and how much riding?[/quote']
Wheels were converted about a month ago.
I've ridden every weekend since, probably about 5-6hrs per weekend.
So hasn't had much use, but it's a good start.
Guest Big H
Ben, did not read the whole post....... when you place the BMX tube, what happens to the old valve stem as well as the rubber reinforced area around the valve stem.
What sealant do you use, do you use liquid latex or do you use Sludge? Will the Continental Gravity 26 x 2.3 tyres we use on the tandem work??????
Guest Big H
Ben do you use the whole bmx tyre or do you "slice" away the inner half. I am just a leetle confused as if you use the whole tube the airflow will be blocked by the inner half of the tube.
Guest Big H
Do you also still use rim tape??????
My insulation tape and tubeless valve is still sealing perfectly after 5 months . BB I am going to try the car valve tonight and see if I can get a proper fit . BigH it is always a good idea to use rim tape anyway .
