3m rubber mastic tape
Johno
I found a product by the hardware i think its a 3m product not sure its looks like a roll of rubber with out any adhesive and is used to patch hoses that have a cut in them.
cost me like R30-R40 I cant seem to get the name of it,
  • 3 years later...
butyl tape should be available from most electrical wholesalers as well.
Its used for waterproofing electrical connections.
I wouldn't use it, stuffs sticky as hell and will pick up all the mud along the way.
Its also a pain to remove and more often than not a knife is used to cut it away.
Seems like the Butyl tape and the 3m one isnt exactly the same so I cant comment on 3m one
Does anyone know where to get hold of the 3m rubber mastic 2228 for down tune protection. Thanks
I have a few rolls of Contran kc80 you are welcome to it i also have a box of 3M rolls but need to have a look for it
Thank you very much! Is it the same stuff as the 3M rubber mastic tape?
Yes thick rubber sticky one side used for electrical cabling up to 1000 volts
