Nothing on availability ... This still in the R&D stage?
Pretty much done with all of that, think they're gearing up on getting them to production and into market. Expected release date around Eurobike, more than likely a few weeks after they'll start being available.
Personally quite like the Marathon Almotion for a nice all rounder on my CX bike. Commuting, road and sometimes CX Sundays, infused with beer and blood.
  • 1 month later...
I'm quite keen to go the tubeless route on my Racing 3 wheels, 25mm wide.
My only concern is knowing if they are actually tubeless compatible before I splash out R1600 on a set of Pro One's.
Fulcrums? Yes there are no spoke holes so no tape needed.
Make sure your wheels are actually road tubeless compatible. Your Fulcrums should be the "Two-way fit" type. The critical feature is that the rim's bead MUST have the tubeless profile or else you run the very real risk of blowing the tyre off the rim. It's not enough that the rim is sealed / has no spoke holes. There are many rims that have no spoke holes that are not road tubeless compatible.
I have Fulcrum Racing Zero's Two-way fit and have run Hutchinson Fusion tubeless tires for two years now with no punctures. Awesome technology. Can't wait for the Schwalbe Pro Ones - they are in a league of their own apparently (performance, puncture resistance, weight and comfort).
Edited by openmind
Thanks.
Mine are not the 2-way fit, but the normal Racing 3's (2015 model).
Where can i find Schwalbe One tyroe? I see Evobikes don't have stock
Bike-components.de has 23c in stock. No where else as far as I could determine from my usual online stores. Schwalbe's doing a solid job of building up steep inventories of vaporware, starting with Procore. Pro One is coming in a solid second... <_<
Watch out for a minor weight penalty on them hoops
  • 4 weeks later...
