Specialized Epic or Camber
Roblillie
Hi...i need some advice.
Looking to buy either a Specialized Epic FSR Comp 29 or a Specialized Camber FSR Evo 29......
Whats the real difference in these bikes ?
I enjoy riding...but i will never be on the podium.
Any advice would be much appreciated
Rob
Hi There,
Purely depends on what type of riding you want to do? If racing marathon etc. then take the Epic, if you are going to embark on more technical rides and enjoy the challenges of a technical trail(difficult rock gardens etc.), then go with the Camber.
Cheers
Go for the Camber...much more capable bike, easier to handle in tight stuff...
I have the Camber Comp and love it, my first choice was a Stumpjumper tho but they couldn't get stock when I bought my bike...
Wouldn't touch an Epic...unless I am aiming for a podium spot in races, which I am not...The Epic is a great bike for its designed purpose which is to be fast and twitchy handling - if you are on a bike after 4 hours and start getting tired then the twitchy handling can start equating to crashes...
Buy the Camber or (insert tjop's bike of choice here). :P But honestly Camber is a capable bike and the more relaxed ride will do wonders. Either way your choices both good bikes.
ok, in short (comparing the Camber Comp and Epic Comp) bikes:
camber:
120mm revelation fork
can only hold 1 bottle cage
Epic
100mm reba fork
can hold 2 bottle cages (1 sml and 1 lrg bottle).
both come with 2 x 10 groupo's
neither have a dropper post (all the cambers above the camber comp spec has the command post with either 100mm or 125mm travel on the post, while the epic expert has the command XCP post with 35mm travel).
Neither has brain tech (where higher in the range both have brain dampening tech)
Both good quality mid-range bikes.
Do you mind lugging a camelbak around?
is it a 2015 Camber expert evo (there are no more evo's in 2016, as they're all "evo" now)?  BTW, "Evo" indicates a relaxed head tube angle and slightly more sus travel than a regular camber.
I would go for the Camber EVO unless you're a real race snake with an saseeding in the 20s...
The Camber Evo was widely rated ***** by the overseas bike mags and as, probably, the best trail / all-round bike Spez makes.
The main differences in the bikes relates to their sus travel (100mm vs 120mm) and head tube angle - the Evo's angle is a lot more relaxed.
The bikes are intended for different purposes - the Epic is a RACE machine, while the Camber is more TRAIL / FUN / singletrack focused.
Go test them both, if possible.
Hey Rob, essentially camber is a trail bike. Epic is for XC podiums...which you're not interested in....so, go with the camber. Easy to do races with too, climbs well, descends better, especially the EVO's (lotsa fun). Always try get the best frame you can afford, and can upgrade rest at later stage.
I have a Camber Comp Carbon great bike I put on a dropper post and lighter wheels and hubs also no Brain so cheaper and easier to maintain.
For me the best bike for a doo all capabilities as can doe XC/trail, I am no race snake but love to ride which is what you sound like so go with a Camber you will not be disappointed
Have a look at the new 2016 Camber amazing bike
I've had an epic. Now on a camber expert Evo. Just done W2W and painful cheeks due to three days of smiling!!! When you get past 3 hours in the saddle, the Camber just makes soooooo much sense. For me it's Camber all the way.
Bought my self a Camber the weekend
Busy upgrading the components to XX Sram.
I tested it one morning, and it just FELT RIGHT!!!!!
A 2016?  Which model???  Tell us more!!!
Yup,  2016 dressed in Black and white stickers from Complete Cyclist.
Busy upgrading the groupset etc with the private bike guru.
I went Camber Alu, purely for the price and again because I have a carbon at home ( Shhhht the wife things its a cheap bike),  my Fatty Spez is Alu and man that Frame is strong!!!!
Pics ASAP.
