best rotors??
tunariaan
I currently use Ashima rotors on Formula R1 brakes
feels like i dont have enough stopping power.
Whats the best rotor in your opinion.
i have used hope before and its pretty good
Riaan
Discs with lots of holes where there should be metal will be lighter but there is also less friction and they get hotter under load.
I'm very happy with shimano discs. Not the lightest but robust and they work well.
Brakes will work better if no air in the hydraulics and when the pistons/pads are aligned perfectly parallel to the disc surface.
ARE YOU SURE the problem is not the Formula R1's?
nope...i like them have had them for 2 years and not one rebleed or anything
but i have only used hope on them and ashima
Riaan
thx i understand how the pad and breaks work
Ja my point was that if everything is mechanically healthy then some discs are more air space than metal - go for the ones with more friction area. You can also go up a size for more stopping power
Went from Hope and Alligator  to Shimano XT Icetech and never looked back :thumbup:  :thumbup:
weight 90kg
seems like most guys talk about the ice tech so might try it out
Does not matter which rotors it is.......when in motion keep fingers as far away as possible.
Excellent mini-amputation devices......or as the case this morning......
......instant manicure device.......(sailor language cum laude).
Damn! That'll make your eyes water, and have the local priest saying prayers for you!
Ice tech rotors are the bomb!
think so yes
i can clearly feel the difference between ashima and hope rotors
Riaan
Would a change of pad material not make more difference?
Icetech rotors are alu sandwiched between steel facings. They really do run cooler than normal discs. Dunno if it makes them stop better but v happy with mine.
