No, Im in Durbs. But am officially on the hunt for new levers.
so i bought new M8000 levers only from hibike costed around 400 each, and couldn't be happier
  • Replies 182
  • 8 months later...
My slx m675 has this problem ... wtf??? i Cant open this screw ???
It shouldn't be a problem? Have you taken the rest of the lever apart?
When I try to remove the first screw that speaks the tutorial, the key turns false, I have to buy another one better.
But I saw that it is necessary to remove this bolt too ... or not?
That's the question, how can I remove this screw? I've never seen a screwdriver like this.
taken from here http://forums.mtbr.com/brake-time/shimano-zent-812550.html#post9831481
http://forums.mtbr.com/attachments/brake-time/734475d1359601749t-shimano-zent-setup.jpg
http://forums.mtbr.com/attachments/brake-time/734477d1359601749t-shimano-zent-lever.jpg
http://ficdn.mtbr.com/images/misc/paperclip.png Attached Images http://forums.mtbr.com/attachments/brake-time/734476d1351705069-shimano-zent-tip.jpg
OMG, ok, thanks. I'll try
Yes put the lever on a flat surface use an allen key the slight smaller than the pin and give it a soft tap with a rubber mallet, or even a hit with your hand if you have man hands, and not computer hands like me
